Puch Estoril vs Techno Circuit: Lowend champ!
So I have a 260lb rider on a kitted e50 magnum. Running an uncased matched 70cc kstar, 15 sha, boss pipe, tighted 2 shoe, and 15/45 gearing. It is kind of sluggish off the line. What really sucks is he lives in a hilly area and needs to get moving. I know a ZA50 would have been better, but whatever. So my question is would a techno circuit or estoril help his overall takeoff? I dont care to get past 35mph, just climb some hills. The boss is really killing the lowend. I'm on a budget and he doesn't want the screaming loud proma circuit. Also would replacing the 15 sha with a 14.12 help the lowend. I know bings are an option, but i already have the 14.12 sha.
Thanks,
Marshall
and yeah this is for my father.
Re: Puch Estoril vs Techno Circuit: Lowend champ!
All circuit pipes are loud, so if you really want the quietest torque pipe, get the estoril.
I've got a Tecno Circuit and haven't found any vast performance gains at low end with my stock e50, but a decent mid to top blasting pipe on my stock swinger. results may vary with your kit though. just a thought, but maybe a 3-shoe with some stiffer springs might be better? someone slap me if that's a crazy thought, i need to stop having those!
Three shoe clutch with blue springs would help also
I am running a techno circuit on a e50, stock cylinder, 12mm bing+high intake airfilter. Without even upgrading the carb yet i hit 38 on flat and 42 down a slight hill on my heavy magnum. Bring on the large carb and some porting. Only issue i have had is the pipe kept vibrating loose, some locktight later no probs
I know I don't run puchs but I have a techno circuit on my tomos. I have put an estoril on just to see the power differences. I will say, the estoril is allows for a smoother power band, the circuit is just like BAM POWER.
tighten those srpings down and bigger carb equals better low end.
go wit hthe proma circuit, best pipe ever.
its loud, but you know there is that saying,.... loud pipes save lives.
agker
port match for power.
The quick and easy would be to change the gearing. You also mentioned this was on a budget. A new front sprocket is like $10ish. Fucking case match and port match too. That's free, just takes some work.
