Anyone put stock fenders on the puch ebrs? (the cheaper set). Did you have to cut em?
the MKII chrome ones look they'll bolt right up without any mods..
i quickly tried with my stock Maxi fender yesterday, and it definitely requires a little modification to work, but nothing too crazy. my plan is to cut the side runners off completely and then drill a couple holes on the top of the fender to bolt it to the EBR brace i have on there. and then re-attach the other braces back on the wheel bolts. i'm sure this has been done many times before but am curious if there are any weird things i should look out for?
It depends on the fender... i think there are two different maxi fenders... and it also depends on what tires you use.
i used gazelles and i cut half of my front fender off... and it worked..
my other maxi didn't work at all with the ebrs.
I have ebrs and a maxi MKII chrome fender with fork brace. I'm also running Gazelles (2.25") with snowflakes. Absolutely no mounting problems for my fender or fork brace.
Any1 else?
dude.
crome, yes.
painted, not without modification.
i'll have my patina one mounted by the weekend.. such a straight forward that it shouldn't even require thought. i will post a pic for the benefit of search when i'm done.
Thanks for the pic, hows the ride on those forks compared to stock?
depends on your current setup. my whole front end was already pretty worn out and sketchy around 40. i replaced all the bearings and cups as well. 1000% better then what i had. solid to warp speed..
