garelli UPGRADE
Hey mates, I've got a 17.5 PHBG, polini kit and a TM3 exhaust for my garelli ssxl. Very excited as this is my first real mod. One question: what intake manifolds would everyone recommend?
love,
greg.
Re: garelli UPGRADE
polini. howd you get a 17.5mm carb? should have done homework and got 20mm carb matched to 20mm polini intake. btw hows the tm3 look? i want one. and does it match right up? just bolt on and go?
Re: garelli UPGRADE
17.5 came in a package deal. TM3 apparently needs a bit of bending to fit just right, but I'll let you know when it gets here. so for the 17.5, what will I have to do to make it fit a polini intake?
Re: garelli UPGRADE
it should fit fine. it might make it a bit harder to tune since the intake is bigger than the ID of the carb venturi, but nothing to worry about.
Re: garelli UPGRADE
any chance someone could link to the appropriate intake so I know exactly what you're talking about? Thanks.
Re: garelli UPGRADE
Re: garelli UPGRADE
Like I said you need to piece your project together.. NO..just sells.. hey throw me together.. Its moped parts.. design to run MX racing or road course. :) cheers that you found it.
Re: garelli UPGRADE
Greg what exactly did you need to do to that TM3? Was it hitting the case or just pedal clearance issues?
Re: garelli UPGRADE
I've only heard that it'll need some slight bending, the part should be here this afternoon, then I'ma head to the shop and see what's up. I'll keep you posted.
Re: garelli UPGRADE
Thanks greg.
Re: garelli UPGRADE
Update: still waiting on my intake to put on my kit and carb, and the pipe definitely needs to be bent. It seems to have been constructed to fit my kit, but it hits the clutch casing no matter what. Somewhat frustrating. Luckily there's a place down the street that does it for ten bucks. Should be ready and kitted up before Bomb Prom!
