Blue smoke!
When i run my 1979 batavus starflite top tank the engine is a laura m48, it makes alot of blue smoke. The ratio is 50:1. It will get up to 30 mph, but with very low compression and acceleration. Is all this blue smoke normal? What could be the problem? Any help would be appreciated! Thanx
Re: Blue smoke!
please go to the repair forum. but it sounds lik eyou have a seal blown somewhere
Re: Blue smoke!
I thought blue smoke was too rich and white smoke was blown seal? How's your spark plug look? Is it really black and carbon-y?
Re: Blue smoke!
Do you have that really cheap two stroke oil for boats in it. The marine use one.?
Re: Blue smoke!
Blue is burning oil. The hint is that you said low compression. Pull the head and check the cylinder for scratches , a quick hone job and a new ring should fix you up .
Re: Blue smoke!
New Pope?
Re: Blue smoke!
ha
