i own a 1977 puch maxii andi just recieved a techno bullet exhaust, and bing 14 mm carb.. the problem is it will not idle at all its idled way to high and will not go down.. ne ideas?
idling problem
Re: idling problem
Check your throttle cable tension (if it's too tight, it will do that) and also check for air leaks (air leaks will make it do that).
Re: idling problem
im going to guess its air leaks cuz i couldnt tighten the exhaust all the way cuz their wasnt enough space to get the socket or cresent wrench on it.. thanks ill let you know if it helps
Re: idling problem
Sometimes I use the open end of the wrench with a screwdriver (or something else like that) through the closed end .... like the wrench is perpendicular to the ground and engine. It takes forever and it's a PITA, but it usually works for me.
Re: idling problem
or you can take a a hammer and put a nice dent in your new pipe. my boss was 2nd hand and already a little beat up. it worked great!
did you upjet at all?
