Re: Super moped!
Brian /
Stuffed crank only increases you crankcase compression not engine compression. Less crankcase volume means that the air/fuel mix in the crankcase is under more pressure when the transfers open. This causes better filling of the cylinder, and better mixing as well. The only gain you will see is a little bit of low end torque, doesn't affect top end hardly at all.
