Did you read the article on motobecane porting in the wiki? Carbide dremel bits like the dremel 570 work good, bit moderate porting can be done with needle files. It'd take longer but you can be more careful. Be sure to chamfer port windows when finished and thoroughly wash the cylinder to remove any metal shavings.
