Re: qt50 gear ratios and rpm explained
Ryan M /
lol. were you the one that pushed me into the inside of that last real corner before the straight so hard my rear end stepped out and got caught in your bike? Hard racing for sure, I was trying to avoid the inside curb and you at the same time. lol if so I'm really sorry about that I should of just grabbed a handful of brake and let you over take me in that corner. I'm so very sorry. On a different note. This pipe I originally built on friday for my friends solo odyssey. I designed it for 8Krpm but after it was built I remeasured it and it's more like a 9Krpm pipe. It was horrible on his bike. I doubt he could even free rev his engine to that speed, what was I thinking. It made his bike start four stroking like crazy and his take off was ill affected also so we took it off. So about an hour ago I cut of the head pipe that was just an extra stock head pipe for his solo and I welded on a stock head pipe from an extra qt pipe. At about 40mph it kicked in strong and was pulling past 45mph hard but I ran out of road, wasn't wearing a helmet and remembered a picture of a piston with a hole in the exhaust port side from running a high rpm pipe. The bad part is below 40mph it has half the power of my other pipe. At least it's fun for a speed run, time to get the gps and camera out....
  qt50 gear ratios and rpm explainedTopic by: Ryan Ryan 05/29/09 08:49AM
  Re: qt50 gear ratios and rpm explainedRe: paul h paul h 08/29/09 03:56PM
  Re: qt50 gear ratios and rpm explainedRe: Josh Josh 09/20/09 03:01AM
  Re: qt50 gear ratios and rpm explainedRe: Josh Josh 09/20/09 03:41AM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 02:00AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/20/09 05:11PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/21/09 03:00AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/21/09 02:39PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/21/09 06:05PM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/21/09 06:10PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/24/09 06:17PM
  Re: qt50 gear ratios and rpm explainedRe: zeke zeke 09/24/09 11:27PM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/24/09 11:41PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 06:59AM
  Re: qt50 gear ratios and rpm explainedRe: Nash . Nash . 04/27/10 05:55AM
  Re: qt50 gear ratios and rpm explainedRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 04/27/10 07:28AM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:01AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 04/27/10 12:59PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 04:15PM
  Re: qt50 gear ratios and rpm explainedRe: bully -+:| bully -+:| 04/27/10 06:38PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:22PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:39PM
  Re: qt50 gear ratios and rpm explainedRe: bully -+:| bully -+:| 04/27/10 09:43PM
