Re: qt50 gear ratios and rpm explained
Ryan M /
That was in no part thanks to original tires(new tubes), a very bent front fork(the top of my tire leans over a lot), a bent frame from crashing in practice that I still haven't straightened and running my tires at 32psi(I didn't even think of it till after that weekend). It was all about holding corner speed because my pos will shift into second at about 15mph but will only shift down into first below 5mph. I got a lot of crazy stuff left to do to handle corners even better but at least I got this done tonight.
This way I can lean it farther without scraping the pegs. But I implore anyone with the information I need. Is running a bike at 10K+rpm continuously a bad idea???? .......... where'd I put that dirtbike rim..........
  qt50 gear ratios and rpm explainedTopic by: Ryan Ryan 05/29/09 08:49AM
  Re: qt50 gear ratios and rpm explainedRe: paul h paul h 08/29/09 03:56PM
  Re: qt50 gear ratios and rpm explainedRe: Josh Josh 09/20/09 03:01AM
  Re: qt50 gear ratios and rpm explainedRe: Josh Josh 09/20/09 03:41AM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 02:00AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/20/09 05:11PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/21/09 03:00AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/21/09 02:39PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/21/09 06:05PM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/21/09 06:10PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/24/09 06:17PM
  Re: qt50 gear ratios and rpm explainedRe: zeke zeke 09/24/09 11:27PM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/24/09 11:41PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 06:59AM
  Re: qt50 gear ratios and rpm explainedRe: Nash . Nash . 04/27/10 05:55AM
  Re: qt50 gear ratios and rpm explainedRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 04/27/10 07:28AM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:01AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 04/27/10 12:59PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 04:15PM
  Re: qt50 gear ratios and rpm explainedRe: bully -+:| bully -+:| 04/27/10 06:38PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:22PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:39PM
  Re: qt50 gear ratios and rpm explainedRe: bully -+:| bully -+:| 04/27/10 09:43PM
