Re: qt50 gear ratios and rpm explained
zeke /
ratio is how big your cylinder is, should be 50ccish, to how much space is above that ,the empty space in your head. so if you cc is 50 then you cram it into your head which has 5cc of space you just got a 10-1 ratio. to up the compression ratio and compression you make your head smaller usually done by milling or lathing the head making it shorter.
  qt50 gear ratios and rpm explainedTopic by: Ryan Ryan 05/29/09 08:49AM
  Re: qt50 gear ratios and rpm explainedRe: paul h paul h 08/29/09 03:56PM
  Re: qt50 gear ratios and rpm explainedRe: Josh Josh 09/20/09 03:01AM
  Re: qt50 gear ratios and rpm explainedRe: Josh Josh 09/20/09 03:41AM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 02:00AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/20/09 05:11PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/21/09 03:00AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/21/09 02:39PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/21/09 06:05PM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/21/09 06:10PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/24/09 06:17PM
  Re: qt50 gear ratios and rpm explainedRe: zeke zeke 09/24/09 11:27PM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/24/09 11:41PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 06:59AM
  Re: qt50 gear ratios and rpm explainedRe: Nash . Nash . 04/27/10 05:55AM
  Re: qt50 gear ratios and rpm explainedRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 04/27/10 07:28AM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:01AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 04/27/10 12:59PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 04:15PM
  Re: qt50 gear ratios and rpm explainedRe: bully -+:| bully -+:| 04/27/10 06:38PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:22PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:39PM
  Re: qt50 gear ratios and rpm explainedRe: bully -+:| bully -+:| 04/27/10 09:43PM
