Re: qt50 gear ratios and rpm explained
Flagrant - /
yea. you could also move your compression ratio up to 10:1 or a psi reading of 147
  qt50 gear ratios and rpm explainedTopic by: Ryan Ryan 05/29/09 08:49AM
  Re: qt50 gear ratios and rpm explainedRe: paul h paul h 08/29/09 03:56PM
  Re: qt50 gear ratios and rpm explainedRe: Josh Josh 09/20/09 03:01AM
  Re: qt50 gear ratios and rpm explainedRe: Josh Josh 09/20/09 03:41AM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 02:00AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/20/09 05:11PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/21/09 03:00AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/21/09 02:39PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/21/09 06:05PM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/21/09 06:10PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/24/09 06:17PM
  Re: qt50 gear ratios and rpm explainedRe: zeke zeke 09/24/09 11:27PM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/24/09 11:41PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 06:59AM
  Re: qt50 gear ratios and rpm explainedRe: Nash . Nash . 04/27/10 05:55AM
  Re: qt50 gear ratios and rpm explainedRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 04/27/10 07:28AM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:01AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 04/27/10 12:59PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 04:15PM
  Re: qt50 gear ratios and rpm explainedRe: bully -+:| bully -+:| 04/27/10 06:38PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:22PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:39PM
  Re: qt50 gear ratios and rpm explainedRe: bully -+:| bully -+:| 04/27/10 09:43PM
