qt50 gear ratios and rpm explained
Ryan /
It's 4:38am and I can't sleep. Yesterday was the same so I decided to tear down my spare motor and count gear teeth.
There are three sets or gear reductions in the qt50 motor, one on the clutch side, one one the output side and the last in the rear end. The clutch side is 33 to 63 teeth, the output side is 15 to 19 teeth and the stock rear is 10 to 57 teeth. With the stock wheel circumference of 1,422mm the rear wheel does 565.6rpm at 30mph. Engine rpm is 7,791 at 30mph. I'd heard stories that this little motor is capable of 13k rpm. At 13k rpm you'd be going almost exactly 50mph which I don't understand how cuz before swapping rears to the pw I was only hitting 32mph with a bunch of mods but still running my 50cc jug. I'm wondering what's the fastest anyone has got a qt50 while still running the 50cc jug and stock gears? And what they did to achieve it. Also I ordered my yt60 jug and piston etc. and they're on the way but I'm fabing a pipe and need the exhaust flange's port diameter for my pipe calculator, any one know what the exhaust flange's port diameter is or is it the same as the stock qt jug? Thanks and I hoped I helped some one by posting this info. Ryan.
  qt50 gear ratios and rpm explainedTopic by: Ryan Ryan 05/29/09 08:49AM
  Re: qt50 gear ratios and rpm explainedRe: paul h paul h 08/29/09 03:56PM
  Re: qt50 gear ratios and rpm explainedRe: Josh Josh 09/20/09 03:01AM
  Re: qt50 gear ratios and rpm explainedRe: Josh Josh 09/20/09 03:41AM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 02:00AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/20/09 05:11PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/21/09 03:00AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/21/09 02:39PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/21/09 06:05PM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/21/09 06:10PM
  Re: qt50 gear ratios and rpm explainedRe: Bear Dave Bear Dave 09/24/09 06:17PM
  Re: qt50 gear ratios and rpm explainedRe: zeke zeke 09/24/09 11:27PM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 09/24/09 11:41PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 06:59AM
  Re: qt50 gear ratios and rpm explainedRe: Nash . Nash . 04/27/10 05:55AM
  Re: qt50 gear ratios and rpm explainedRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 04/27/10 07:28AM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:01AM
  Re: qt50 gear ratios and rpm explainedRe: Flagrant - Flagrant - 04/27/10 12:59PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 04:15PM
  Re: qt50 gear ratios and rpm explainedRe: bully -+:| bully -+:| 04/27/10 06:38PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:22PM
  Re: qt50 gear ratios and rpm explainedRe: Ryan M Ryan M 04/27/10 08:39PM
  Re: qt50 gear ratios and rpm explainedRe: bully -+:| bully -+:| 04/27/10 09:43PM
