Re: a35 vs a55
Saabsonettguy . /
The bottom ends are essentially the same however the a55 has bigger transfers in the case. This will make matching the case to a large kit much easier. Of course since your splitting the cases to match them anyway you could always just have someone weld a little extra material on the a35 cases. If your going all out, you can run a hpi inner rotor ignition on either motor.
