a35 vs a55
they are both sweet but witch 1 has more tuning potencial
if you where going to get a new tomos and where able to pic a a55 in the box or and a35 in the box witch would you get and y
big transfers on the a55
a35
no rev limit on the cdi
better trans
not made in india
Re: a35 vs a55
tha a35 cdi does have a rev limiter btw
its just not as bad as the a55's
Re: a35 vs a55
not the early a35
Re: a35 vs a55
A55 in a heartbeat, then get a cdi down the road
Re: a35 vs a55
not all a55 were made in india..... the ones that have no rabbit on the right side cover are slovenian made....
Re: a35 vs a55
Whats wrong with Indian manufacturing?
Re: a35 vs a55
get the a55 and try to retrofit treats new 70cc reed kit for puch
Re: a35 vs a55
I dont understand....why wouldnt you just get the tomos airsal kit, theyre the same thing, i thought
unless the tomos one is a 64cc, but you can still get the 70cc alukit and be just as good
Re: a35 vs a55
The bottom ends are essentially the same however the a55 has bigger transfers in the case. This will make matching the case to a large kit much easier. Of course since your splitting the cases to match them anyway you could always just have someone weld a little extra material on the a35 cases. If your going all out, you can run a hpi inner rotor ignition on either motor.
Re: a35 vs a55
ahh sometimes I don't think things through. I drift in and out.
I didn't realize alukit was only 99 bucks. I was thinking budget.
Re: a35 vs a55
A35. I heard the A55 trans shifts at like, 8mph.
Re: a35 vs a55
going a55 and going to do 50mph on the stock kit than go 65 polini and do 55 but get their fast sweet and thank you
Re: a35 vs a55
i have an A55 and the type f fluid i think it is, makes you shift earlier. i changed to belray sae 70 or something like that and it shifts around 16mph verses 13-14mph. the two mph difference makes getting to top speed alot quicker in my opinion.
Re: a35 vs a55
I like A3's better than both. But A35 better than A55.
Re: a35 vs a55
only a35 that is not rev limited have points.
a55 is soo fast stock.
all tomos mopeds are pretty awesome. soilidish transmisssion that are tunable, reeds and piston ports all awesome.
`SABAT!
Re: a35 vs a55
are you kidding me .... im using 5w 30 in my a55 and im getting my shifts out to 27mph
Re: a35 vs a55
some dude gave me a kinetic for free. by default, i like indian manufacturing.
seriously, i've heard a bunch of crap about them, but i've not worked on this thing yet. looks kinda cheesy, but most mopeds have those aspects.
give props for making one and shipping it here to US. not too many peds come here.
