Need a mechanic in Chicago for carb jetting.
Can anyone, perform a basic carb tune for me? I have an A55 with an Airsal kit, that is nicely broken in, and needs a downjet. $$$ for help.
Thanks!
Re: Need a mechanic in Chicago for carb jetting.
Conrad Conrad /
paypal me $5 and I'll take photos and walk you through how to do it.
Or just take the float bowl off your carb, look at the number stamped into the jet, order a few smaller from Treats, wait a few days for them to arrive, unscrew the old jet, screw in the new jet, run a plug chop to make sure you're not too lean (which you shouldn't be if you don't go down very many sizes), and call it good. I don't have an A55, so I can't take pictures, but there are videos out there for carb re-jetting (not for your carb, but close ones, and the concept is the same).
Conrad Conrad /
What I don't understand is how managed to put a kit on and still don't know how to jet. I guess you could've bought the moped used.
If you really want photos, I'll take some for you. free.
Or had someone install it. Wrenching isn't for everyone... I'm sure Warbux probably hooked it up for him last season...
Go on utube.com and type in keywords like lancecampeau and look to see which video is about jetting a carb. he has a good video on how to change the jet. He also shows you it step by step. I'm sure if you watch the video by him you will understand it perfectly.
He shows it on a streetmate but it is the same a55 engine on all newer tomos a55 mopeds.
