Re: Ninja G3 on stock AV7
steve /
i went rounded edges. i think perfect oval would be a bit hard. but yes, dremel out the inside window to whatever dimension it says. then lead that gradually back to the outside window, so that it matches with whatever your intake is like. get me? make sure you chamfer your edges real good and make sure it is all surgically clean before you put it all back together.
