14 puch intake on 75cc polini kit, and 14:12 sha
will that puch intake and like an 80 jet be chill with the break in of the kit?
the stock gitane intake is tiny as shit and i don't think the cylinder will be lubricated enuf with that tiny, but is the 14 OKAY?
Re: 14 puch intake on 75cc polini kit, and 14:12 s
#68 jet on that set up justice.
thanks johno, is that what you did? btw idk why i dont have your number anymore. did my phone get mad at you?
thats what we used in joshua'she had that same setup
the carb is actually a 12mm... seize city, been done before.
hey dude,
just got yr call about that. I would say it would be a good idea to maybe bore the 12mm side to 14 so its a 14mm setup all around but other than that you will probably be ok. in theory they should run fine with a carb of that size. Just make sure you are jetted correctly. The concern in my mind about 14.12 shas isn't the actual size of the carb as if anything it will restrict only the airflow? -the concern i have is the idle jet and the sizes of the midrange circuits in those carbs. as they are tiny and non-tunable. I ran a 75 polini on a 16 sha with 15 intake and it was great. so a 14 setup won't be terrible. go for it. just jet it rich. and premix rich.
