Re: HPI light coil cure pt. 2
Ƽɧ▲ɴƹ β /
Like I thought, the light is bright but the throw kind of sucks. The bulb sits where a stock one does, and it's in a reflector, so it's the best I can do. Safe enough to be seen, and if you are running a HPI your bike will rev up so instantly that you will only be lacking light at idle. Just blip your throttle a little if you need cars to not run into you from behind. :)
