Re: Hobbit woes continue
Gym-Me IRE /
yeah stock seals...Im thinking its the culprit!
Steve: Its getting hella fuel, I though tthat was it at first...so I elimnated the petcock and shotguned it direct to the carb, Ive rplace the carb, it never did idle with the stock carb, so PHBG keeps it idle, but its adjusted way high! and it surges...
Im running a Polini, performance reeds, PHBG 19mm, Ive tried 90-104 jets...I got a clean tank, and its top tank, Ive run with the cap off...so its not a vaccume issue, its got to be the seals and or bearings....everything is tight tigh ttight! Checked over and under 100+ times...Im very meticulous. The bottom end is the only thing untouched.
Thanks for the responses!
