So im finished building this SSXL, i want to know what people run for Timing on the CEV Stators for these because i know with most garrelli's over-heating can be a issue.
also what kind of speeds to expect, im gettting power up to 25ish MPH
i beleive the main jet in the 14:12 SHA is a 55, and im thinking its a bit lean.
im about to rebuild the exhaust and check for carbon build up in the exhaust port/manifold, and a b5es plug in attemp to raise compression.
also as with most italian bikes it has the dumb brake light has to be grounded for ignition to work thing, i guess a 12v led is too resistive? it dies every time i use the brakes.
so timing?
and good tricks for more compression? top speed?
what stock intake is best, as i have a few...
thanks in advance.
thanks in advance
