and what did you use? just 1/4" copper pipe from the home depot??
I want to know also i thought it was gas line? Mabe lp gas line?
you don't need them.
Using them helps a lot. Just looking for someone who had an easy solution.
im pretty sure it was 1/4 inch piping. just take you kit and a stud to home depot. make sure it fits there.
1/4 fuel line from pep boys. it comes in a coil, u have to straiten it out but it worked great.
i made only two and put them on top right/bottom left studs. i don't know my measurement, i eyeballed it, left about a 1/4 inch outside the jug. the hi comp treat head holes were a little small but a little sanding made it perfect. i really like the way it turned out. a whole bunch of play became a really small amout of play.
1/4" ID Brake line from auto parts store
Just bought a 20" long piece for $3.74.
bronze shims from ACE HARDWARE.
^devin, what isle?
excellent suggestions!! i never really thought of fuel line, thats definitely a cheap and easy solution.
im def gonna look at ace for the bronze shims.. is it a plubming dept item or electric?
bronze shim isle, duh
Would you tell a noob what the stud shims are for?
I looked at ace and couldn't find the right size shim... Can you post a picture of it so that I know what to look for? I really like the idea of everything sitting perfectly centered on the studs... Less airleak possibilities.
i just took my studs down to tha local harware store and found this copper tube....
here they are !installedhttp://i696.photobucket.com/albums/vv330/mustanghardy/100_1419.jpg!
Centers the studs keeps em from breaking helps the cyl cooling...
so basically 1/4 inch OD is all you need and they will slide into the cylinder holes then?
wont that make the bolt not fit right?
they fit, if you do it right, hey dremel dude...thats what i got, comes in a coil right? i only made two. mime go into the head a little bit too. for shimmy shimmy yah type shimming. shimmy yeah shimmy yuh. shimm up my kit so i can blast alla yuh.
