Re: How does this look? (puch polini port work)
the seized polini looks fine, probably would need a piston or something to fill that whole on the intake portion of the skirt. As far as getting it good to run, just clean it all up. Smooth out the piston if it is rough, and get the gunk off the cylinder (if its built up aluminum). I'd guess that seize was due to the intake warping; in fact I think most if not all intake seized polinis are.
  How does this look? (puch polini port work)Topic by: Motobee Goode Motobee Goode 05/17/09 03:42AM
  Re: How does this look? (puch polini port work)Re: SABAT! andDestroy SABAT! andDestroy 05/17/09 04:16AM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 05/17/09 04:35AM
  Re: How does this look? (puch polini port work)Re: Motobee Goode Motobee Goode 05/17/09 04:50AM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 05/17/09 05:12AM
  Re: How does this look? (puch polini port work)Re: c m c m 05/18/09 12:14AM
  Re: How does this look? (puch polini port work)Re: rockles rockles 05/18/09 02:00AM
  Re: How does this look? (puch polini port work)Re: Orphan Frick Orphan Frick 05/18/09 04:08PM
  Re: How does this look? (puch polini port work)Re: c m c m 05/19/09 10:37AM
  Re: How does this look? (puch polini port work)Re: rockles rockles 05/19/09 11:13AM
  Re: How does this look? (puch polini port work)Re: Frank Tunna Frank Tunna 02/16/10 11:28PM
  Re: How does this look? (puch polini port work)Re: mattology - mattology - 02/16/10 11:53PM
  Re: How does this look? (puch polini port work)Re: the worst terry the worst terry 02/17/10 12:13AM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/17/10 01:22AM
  Re: How does this look? (puch polini port work)Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/17/10 02:16AM
  Re: How does this look? (puch polini port work)Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/17/10 02:17AM
  Re: How does this look? (puch polini port work)Re: Gabe Bandit Gabe Bandit 02/17/10 12:03PM
  Re: How does this look? (puch polini port work)Re: Tom STL Tom STL 02/17/10 12:47PM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/17/10 12:50PM
  Re: How does this look? (puch polini port work)Re: Tom STL Tom STL 02/17/10 01:13PM
  Re: How does this look? (puch polini port work)Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/17/10 03:11PM
  Re: How does this look? (puch polini port work)Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/17/10 03:18PM
  Re: How does this look? (puch polini port work)Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/17/10 03:30PM
  Re: How does this look? (puch polini port work)Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/17/10 07:56PM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/17/10 10:27PM
  Re: How does this look? (puch polini port work)Re: roadent$ craig roadent$ craig 02/17/10 11:41PM
  Re: How does this look? (puch polini port work)Re: Gabe Bandit Gabe Bandit 02/18/10 01:33AM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/18/10 02:34AM
  Re: How does this look? (puch polini port work)Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/18/10 06:13AM
  Re: How does this look? (puch polini port work)Re: Gabe Bandit Gabe Bandit 02/18/10 09:21AM
  Re: How does this look? (puch polini port work)Re: Frank Tunna Frank Tunna 02/19/10 01:28AM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/19/10 04:57AM
  Re: How does this look? (puch polini port work)Re: Charlie BUZZARD Charlie BUZZARD 02/19/10 10:01AM
  Re: How does this look? (puch polini port work)Re: mattology - mattology - 02/19/10 11:09AM
  Re: How does this look? (puch polini port work)Re: Charlie BUZZARD Charlie BUZZARD 02/19/10 11:22AM
  Re: How does this look? (puch polini port work)Re: Gabe Bandit Gabe Bandit 02/19/10 11:35AM
  Re: How does this look? (puch polini port work)Re: Tom STL Tom STL 02/19/10 11:57AM
  Re: How does this look? (puch polini port work)Re: Gabe Bandit Gabe Bandit 02/19/10 12:06PM
  Re: How does this look? (puch polini port work)Re: Tom STL Tom STL 02/19/10 12:24PM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/19/10 02:18PM
  Fill, not File.Re: Frank Tunna Frank Tunna 02/19/10 02:49PM
  Re: Fill, not File.Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/19/10 04:35PM
  Re: Fill, not File.Re: mattology - mattology - 02/19/10 04:55PM
  Re: Fill, not File.Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/19/10 05:36PM
  Re: Fill, not File.Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/19/10 05:49PM
  learn2blastRe: mattology - mattology - 02/20/10 01:52AM
  Re: learn2blastRe: Polini Blasty Gnar Gnar Polini Blasty Gnar Gnar 02/20/10 02:11AM
  This is a good threadRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/20/10 02:33PM
  jsmithRe: Salsa Salsa Salsa Salsa 02/21/10 12:28AM
  jbweldRe: Jon Jon 02/21/10 01:38AM
  Re: jbweldRe: Jon Jon 02/21/10 01:54AM
  Re: jbweldRe: Tom STL Tom STL 02/21/10 02:05AM
  Re: jbweldRe: mattology - mattology - 02/21/10 02:33AM
  Re: jbweldRe: Jon Jon 02/21/10 03:03AM
  Re: jbweldRe: - Summerai - Christine L - Summerai - Christine L 02/21/10 08:26PM
  Re: jbweldRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/21/10 09:50PM
Click here to login.
