Re: How does this look? (puch polini port work)
it looks just like the normal one except its perfectly flat. Its a pretty tedious process because even when you think its good its not. You have to twist and turn the cylinder with the reed block/intake on top to make sure it really is flat (looking into the light).
In all honesty it doesn't have to be perfect if you take proper precautions. Mine was all nice, no leaks but it still warps the cylinder a tad when you torque it all down. I simply sanded my piston down so there is zero friction on the intake bridge of the cylinder. Sure the piston my be a little "loose", but I'd rather it be loose than too tight. Intake leaks are bad, as are warped cylinders.
Mr. Smith, are you running mikuni now or future thoughts?? Still with points? I think my polini has run a 102 or 106 for the past year or so, pretty sure 102 but I'm not 100% on that. When I was running the mikuni on the derbi (w/ polini) I had a leak somewhere, but I ran something stupid like a 220 or so, but eventually settled around 185. It was pretty quick once everything worked almost right.
K, too much writing. Gabe, one day, hopefully sooner than later.
  How does this look? (puch polini port work)Topic by: Motobee Goode Motobee Goode 05/17/09 03:42AM
  Re: How does this look? (puch polini port work)Re: SABAT! andDestroy SABAT! andDestroy 05/17/09 04:16AM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 05/17/09 04:35AM
  Re: How does this look? (puch polini port work)Re: Motobee Goode Motobee Goode 05/17/09 04:50AM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 05/17/09 05:12AM
  Re: How does this look? (puch polini port work)Re: c m c m 05/18/09 12:14AM
  Re: How does this look? (puch polini port work)Re: rockles rockles 05/18/09 02:00AM
  Re: How does this look? (puch polini port work)Re: Orphan Frick Orphan Frick 05/18/09 04:08PM
  Re: How does this look? (puch polini port work)Re: c m c m 05/19/09 10:37AM
  Re: How does this look? (puch polini port work)Re: rockles rockles 05/19/09 11:13AM
  Re: How does this look? (puch polini port work)Re: Frank Tunna Frank Tunna 02/16/10 11:28PM
  Re: How does this look? (puch polini port work)Re: mattology - mattology - 02/16/10 11:53PM
  Re: How does this look? (puch polini port work)Re: the worst terry the worst terry 02/17/10 12:13AM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/17/10 01:22AM
  Re: How does this look? (puch polini port work)Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/17/10 02:16AM
  Re: How does this look? (puch polini port work)Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/17/10 02:17AM
  Re: How does this look? (puch polini port work)Re: Gabe Bandit Gabe Bandit 02/17/10 12:03PM
  Re: How does this look? (puch polini port work)Re: Tom STL Tom STL 02/17/10 12:47PM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/17/10 12:50PM
  Re: How does this look? (puch polini port work)Re: Tom STL Tom STL 02/17/10 01:13PM
  Re: How does this look? (puch polini port work)Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/17/10 03:11PM
  Re: How does this look? (puch polini port work)Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/17/10 03:18PM
  Re: How does this look? (puch polini port work)Re: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/17/10 03:30PM
  Re: How does this look? (puch polini port work)Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/17/10 07:56PM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/17/10 10:27PM
  Re: How does this look? (puch polini port work)Re: roadent$ craig roadent$ craig 02/17/10 11:41PM
  Re: How does this look? (puch polini port work)Re: Gabe Bandit Gabe Bandit 02/18/10 01:33AM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/18/10 02:34AM
  Re: How does this look? (puch polini port work)Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/18/10 06:13AM
  Re: How does this look? (puch polini port work)Re: Gabe Bandit Gabe Bandit 02/18/10 09:21AM
  Re: How does this look? (puch polini port work)Re: Frank Tunna Frank Tunna 02/19/10 01:28AM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/19/10 04:57AM
  Re: How does this look? (puch polini port work)Re: Charlie BUZZARD Charlie BUZZARD 02/19/10 10:01AM
  Re: How does this look? (puch polini port work)Re: mattology - mattology - 02/19/10 11:09AM
  Re: How does this look? (puch polini port work)Re: Charlie BUZZARD Charlie BUZZARD 02/19/10 11:22AM
  Re: How does this look? (puch polini port work)Re: Gabe Bandit Gabe Bandit 02/19/10 11:35AM
  Re: How does this look? (puch polini port work)Re: Tom STL Tom STL 02/19/10 11:57AM
  Re: How does this look? (puch polini port work)Re: Gabe Bandit Gabe Bandit 02/19/10 12:06PM
  Re: How does this look? (puch polini port work)Re: Tom STL Tom STL 02/19/10 12:24PM
  Re: How does this look? (puch polini port work)Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/19/10 02:18PM
  Fill, not File.Re: Frank Tunna Frank Tunna 02/19/10 02:49PM
  Re: Fill, not File.Re: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/19/10 04:35PM
  Re: Fill, not File.Re: mattology - mattology - 02/19/10 04:55PM
  Re: Fill, not File.Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/19/10 05:36PM
  Re: Fill, not File.Re: Blasty Blasty Gnar Gnar Blasty Blasty Gnar Gnar 02/19/10 05:49PM
  learn2blastRe: mattology - mattology - 02/20/10 01:52AM
  Re: learn2blastRe: Polini Blasty Gnar Gnar Polini Blasty Gnar Gnar 02/20/10 02:11AM
  This is a good threadRe: Cold Trailer GARzan Justin Cold Trailer GARzan Justin 02/20/10 02:33PM
  jsmithRe: Salsa Salsa Salsa Salsa 02/21/10 12:28AM
  jbweldRe: Jon Jon 02/21/10 01:38AM
  Re: jbweldRe: Jon Jon 02/21/10 01:54AM
  Re: jbweldRe: Tom STL Tom STL 02/21/10 02:05AM
  Re: jbweldRe: mattology - mattology - 02/21/10 02:33AM
  Re: jbweldRe: Jon Jon 02/21/10 03:03AM
  Re: jbweldRe: - Summerai - Christine L - Summerai - Christine L 02/21/10 08:26PM
  Re: jbweldRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 02/21/10 09:50PM
Want to reply to this thread?
