Anyone got any tips on hardwiring and urban express? I just want wire for my headlight, tail light, and kill switch..
Simple. The ignition key works by connecting the lighting circuit wires together and DISCONNECTING the ignition wires. So if you unplug the key, the bike will run but the lights won't work. You then just connect the two lighting wires together and you've got lights. Keep in mind this will run down your battery, and running an Express with a dead battery will blow the headlight.
