Just bought some ebr's for my maxi. Any trick to bolting them on, or do they slip right on? Do I need the fork bearings from the stock froks?
Thanks
Thanks
yea use your old bearings also you need to take the cone off of your old forks
Just reuse the old bearings and re-grease them. You're going to have to remove the bottom race from the stock forks. This is super easy to do with some heat and flat head screwdrivers.
yup. word of advice....lay down a towel or something to catch all the ball bearings when you remove your stock forks. They have a tendency to fall out and roll everywhere. Im sure many people have learned this the hard way. :T
