Re: New Carb for my Urban Express
Take three weights out of your variator and your 0-20mph should improve dramatically.
Just make sure the remaining weights are spaced evenly so that your variator is balanced.
You can use your stock throttle cable. Just take a file and grind the knarp down till it fits your carb slide. I am assuming you went with a dellorto 16.16.
