Re: PA-50 reed block and jetting, (new settup)
That reed block will be fine. Install the new reed material on the old block...(I actually dremeled away some material on my reed block to open it up a bit for better/more flow)
As for the carb setup, I run the same thing.
I've got a 95 main in mine. 90 is really close to what you'll need. I've heard others have settled on a 93 main for their kits.
Remember to use the flat topper piece to the carb! The regular carb topper and elbow will not work!
Good luck.
J
