peugeot stroker timing
so i have a bit of a sputter up top it is electrical i can tell that. the timing is set at 2mm before tdc what kind of timing are you guys using with the molossi stroker crank. i feel like it may have something to do with it cause it does change the port timing.
lemmi know
Re: peugeot stroker timing
does not change port timing. treated. try a little less than 2mm btdc.
word will do. thanks
