dellorto SHA 16 w/ perf. filter on a maxi
ok so i’ve got a new kit, a new intake, a new carb and air filter, and when I tried to put it together i realized that it doesn’t even almost fit. the intake is puch 15mm intake for dellorto SHA carbs, but when i put the carb on it doesn’t even fit between the intake and frame without being cocked to one side quite a bit, because the top of the carb where the throttle cable joins hits the frame, and there’s barely enough room for the stock filter that came on the carb, and there’s no possible way the hi-flow filter is going to fit there. is there an intake i can buy that will put the carb/filter a little higher up and more out to the side? or do i just have to make a new one? I would love to see some pictures of other people’s solutions with similar maxi/carb situations
Re: dellorto SHA 16 w/ perf. filter on a maxi
Griffin Applicable /
it's ok for the carb to be on an angle. you can ditch the stock filter and make one of pantyhose. it will make getting the carb on and off much easier
yep!!
I'm running that on a ZA50 and I had to grind some material off of the oil injecton housing to make it fit if your not running a za50 plese disreguard this post
