treatshq za50 clutch
has any one put the new clutches on from treats?
how do you like them?
did you flip the 2ed gear?
did you change or cut the springs?
thank you
za are so sweet
i cant wait to go 80 metrakit and going way to fast
Re: treatshq za50 clutch
You cant flip the clutch because it wont fit. I have been running the clutches for about 100 miles on my metra 80 and they are pretty nice. It shifts pretty late, about 30-35. I am also using 0w-20 mobil one sythetic oil.
thanks
so you are using a thinner oil for later shiftying I've been doing the opposite and it's not working, guess that's maybee why?
if you use the thinner oil you need to overfill it to make it work
i run 7oz of ATF and 3 to 5oz of 30w and my 65metra holds 1st to like 26 to 28 mph i can all most make it shift later with how i hold the gas
