Re: nc50 gearing
I R E Rick /
the rim swap on the nu will not net you a 5 mph gain , maybe 2 or 3 . If you try to do this on an nc you will find that you have VERY little space between the rear wheele tread and the case . Put a wider , {which will be taller tire on the same rim } You are left with little other option .
