Slanty 5-stars: What the heck??
Pablo Puchasso /
So I after having these things sitting around for a while, I decided to paint them. I began prepping them, and much to my dismay, I discovered that the lever for the brake on the front hub is unlike one I've ever see before. (see attachment). The back one is normal but the front one, as you can see, is just a circular hole. Should I use a normal front brake cable and just run it through the hole, letting the big end catch/pull when I need to brake and hang/dangle the rest of the time? Is there another cable I should be using?
Help? I know this should probably be in repair... sorry.
Re: Slanty 5-stars: What the heck??
Grab a tomos style pinch bolt and call it a day.
Treats has the vespa pinch bolt and it will work on that wheel
Pablo Puchasso /
Ok cool. I've just never used anything but puch stuffz for cabling I guess. Thanks youze guyz.
Or replace the arm with a puch one, I have the same wheels, they are cool. Mine are going black or orange. Good luck with your build max
elliott/ultrav /
yooo mojo- ive had mine sitting for the longest and im like wheel illiterate.. can you post up or email me pictures of the order of parts on the axel please!
i know its hella rookie stuff but i cant figure it out for the life of me! i hate wheels :(
thank you kindly sir
I have one of those levers from a puch that you can just have if it fits, if you want to go that way.
Here you go Elliott
Pablo Puchasso /
looks like someone beat me to it. They come assembled though... mine did at least.
elliott/ultrav /
yea so did mine, but i got them powdercoated and cant find my diagram that i made.. arrghhhh i hate a horrible memory!
thank you kindly though for the diagram :)
They are often referred to as mozzi wheels btw. They come stock on recent model Peugeot mopeds. Use a pinch bolt as intended.
Pablo Puchasso /
Cool. Yeah I see that on the wheel now that I am painting them.
