Malossi 62 19mil dellorto HELP
Hi Guys, I have a 50V with a Malossi 62, I just installed a 19mil dellorto, idles great but when I open up the throttle its like its not getting enough gas. the jet it came with was a 75 to small? should I go up to 80's range or higher? I had 75 jet in my 17 dellorto and was fine. Also do you have to change the needle setting? its driving me crazy, rides well when not a full throttle !!!!
With the same setup I am getting good results with a 45 idle jet, the mixture screw turned almost all the way in, and an 83 or 84 main jet. So yes, I think you are super lean on the main jet if you are running a w7 needle.
Re: Malossi 62 19mil dellorto HELP
Motobee Goode /
Yeah, dont run that. You are getting more air now. Order some jets homie.
Tank you for your help, will change that today, will let you know the outcome.
my buddies malossi threw a wrist pin clip and killed itself the other day. it was scary. maybe he's to blame but be careful with them shits. they rule too much and are so hard to get.
