Do not use that intake gasket, cork will fail on you. Tried it, left me stranded. The vibrations crushes the cork and it will leak on you. The exhaust is weird, no reason to dremel it out like that cause the exhaust ring will cover that part up anyways. Otherwise looks good. The back of the head may hit the top heat fin on the cylinder, maybe, maybe not. Depends on stuff. Let us know how it goes.
Re: Moby porting
