70cc Airsal Head Gasket
So I have a Airsal 70cc Kit on my A55 and I need a new head gasket for it. I've looked and looked every where but I don't know where to get one. What I am wondering is can I put a head gasket from a different moped 70cc kit with the same mounting stud pattern(spacing). What other mopeds have the same mounting stud pattern as the A55. Or I am I going to have to make a gasket for it.
Thanks
Mike
what do you guys think about running with an extra base gasket and no head gasket as an alternative
Re: 70cc Airsal Head Gasket
I'd just clean up the mating surfaces and try running without one, making sure the piston clears first, see if it seals.
pretty sure i've long lost track of which is the head gasket that came with the airsal kit and which are the spare kstar 70cc gaskets i got from el treats. i mean i dont see any difference; hope there isn.t..
You can use a head gasket from any A35 70cc kit also...they are the same size bolt and pattern as the A55
