Re: Puch crank bearing shim problem solved???
rob farmer /
fuck!! my link didn't work!!
http://www.easyparts.nl/showarticles_info/0101076236/0-156-627-607-1047-2170/6203-St-Maxi-Lager-(Nw)-Ring-Versmalde-Binnenring.html
sanding circlips, leaving out parts and shimming, machining cranks, is lame!! we need to find the right bearing!!!!
http://www.easyparts.nl/showarticles_info/0101076236/0-156-627-607-1047-2170/6203-St-Maxi-Lager-(Nw)-Ring-Versmalde-Binnenring.htmllink fail
