Re: Motobecane 50L with parmakit sputters at 20mph
describe the "sputtering."
depending on what that is, you might have a leak somewhere, likely either at the decomp, or your head isnt torqued down right. are you running a head gasket? have you checked compression? will it run fine at full throttle and into high RPMs on the stand?
also, did you align the piston correctly?
  Motobecane 50L with parmakit sputters at 20mphTopic by: Meleah Meleah 05/04/09 08:37PM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: Robert Rosselit Robert Rosselit 05/04/09 09:11PM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: Jesse -B Jesse -B 05/04/09 09:12PM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: Meleah Meleah 05/04/09 11:33PM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: Motobee Goode Motobee Goode 05/05/09 12:59AM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: steve steve 05/05/09 01:04AM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: finny finny 05/05/09 01:51AM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: Nele Nele 05/05/09 03:48AM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: Ben Eberle Ben Eberle 05/05/09 02:05PM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: Nele Nele 05/05/09 03:06PM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: Motobee Goode Motobee Goode 05/06/09 03:55AM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: ***Vanilla Thunder*** ***Vanilla Thunder*** 05/06/09 07:36AM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: Mikey q Mikey q 12/31/09 08:41PM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: CtpEDsHED . CtpEDsHED . 12/31/09 10:25PM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: Jaym Jaym 01/01/10 02:36AM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: Ben Ben 01/02/10 12:29PM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: Rookie Squid Rookie Squid 01/02/10 09:50PM
  Re: Motobecane 50L with parmakit sputters at 20mphRe: Jaym Jaym 01/04/10 07:28PM
Want to reply to this thread?
