Update*
Ok so I replaced the condenser and still no go.
I have also since added a 70cc high comp head, fixed all air leaks, port matched everything, up-jetted and plug chopped to perfection, running a b7hs plug now instead of a b6hs, and re-gapped the points a few times.
So..... I am starting to get pissed off. hours of tunning and mucking with stuff has gotten me almost no where. Except now she runs like a mofo up to 46 ish.
Also whats frustrating is that I am constantly breaking down in front of on lookers and usually teenagers. I don't even try and start it back up anymore I just peddle home.
Also what might be of some concern is the fact that when the engine rev's out the points are arcing onto surrounding areas. Actually its more like the points arm is arcing onto the stator plate. I tried to clean the points and surrounding areas but I don't think it did any good.
