so i bought a cylinder from QK a month ago and ported it per the wiki instructions. I've noticed that it has almost zero low end and hits it's power band kinda high for the variator. (3 ball). Am I correct in assuming that this type of porting will raise the rpm at which the power band is reached and it needs to be corrected by removing weights from the variator? Or does this mean I screwed it up?
