the amount of space I have to work with I don't believe will be enough room for the buyable intakes and my carb to fit on, has anyone else had this problem, and if so what was their solution?
I fit an intake that comes with the metra kits and a 20mm dellorto with a malossi filter in there. You'll have to drop the engine to do it
Yeah man, I put a 24mm mikuni in there. Plenty of space. I ran a 16.16 sha on my piston port a while back. I just had the intake cut (don't cut too much off, or the bottom of the carb will hit the engine) and turned down to fit the shim on the sha.
so u had the 24 mikuni intake and the 16 sha? i have the piston port right now
justice you have the piston port bike. just get the piston port derbi kit on treats. ( would it work on puch as well?) and make an intake out of an old exhaust or something.
just jb weld the carb right on to the cylinder, duh, hold it with rubber bands till it sets (or permanently)... even you could do that, right? maybe not....
