Re: Octane vs. Compression Ratio/PSI Chart
Volume of the head
Exhaust Timing
Squish Band/Piston Clearance
those are the three variables for compression ratio.
  Octane vs. Compression Ratio/PSI ChartTopic by: Jimmy Stucky Jimmy Stucky 04/26/09 11:56PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: elliot elliot 04/27/09 12:54AM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Grande Deluxe Grande Deluxe 04/27/09 01:53PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: T. Snider T. Snider 04/27/09 12:59AM
  Re: Octane vs. Compression Ratio/PSI ChartRe: James G James G 04/27/09 01:59PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Flagrant - Flagrant - 04/27/09 02:17PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Raymond Rexroad Raymond Rexroad 04/27/09 02:20PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: paul paul 04/27/09 02:41PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Jesse Stephenson Jesse Stephenson 04/27/09 02:47PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Flagrant - Flagrant - 04/27/09 04:00PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: CtpEDsHED . CtpEDsHED . 04/27/09 05:32PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Jimmy Stucky Jimmy Stucky 04/27/09 06:03PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: paul paul 04/27/09 06:10PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: SchijnHeilig SchijnHeilig 04/27/09 06:17PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Flagrant - Flagrant - 04/27/09 07:38PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: brendanM brendanM 04/28/09 02:16AM
  Re: Octane vs. Compression Ratio/PSI ChartRe: SABAT! andDestroy SABAT! andDestroy 04/28/09 05:58AM
  Re: Octane vs. Compression Ratio/PSI ChartRe: SchijnHeilig SchijnHeilig 04/28/09 06:17AM
