Re: Octane vs. Compression Ratio/PSI Chart
Jesse Stephenson /
Also for note, because the exhaust is open on a 2-stroke for most of the actual compression stroke they have a seperet rating called corrected compression ratio, which is the volume of the combustion chamber at TDC divided by the volume in the cylinder when the exhaust port is closed. But it all kind of goes to hell with a pipe anyways due to the charging effect of the waves. I've read that some scooter race kits run as high as 15.8:1 but they also have an exhaust duration of about 190 degrees, and only do about 140 psi, on the stand with me kicking it, the pipe will make it much higher at running speeds. Also read that a 125cc with a proper pipe can have as much as 144cc of gas in it due to the pipe, (something like that).
  Octane vs. Compression Ratio/PSI ChartTopic by: Jimmy Stucky Jimmy Stucky 04/26/09 11:56PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: elliot elliot 04/27/09 12:54AM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Grande Deluxe Grande Deluxe 04/27/09 01:53PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: T. Snider T. Snider 04/27/09 12:59AM
  Re: Octane vs. Compression Ratio/PSI ChartRe: James G James G 04/27/09 01:59PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Flagrant - Flagrant - 04/27/09 02:17PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Raymond Rexroad Raymond Rexroad 04/27/09 02:20PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: paul paul 04/27/09 02:41PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Jesse Stephenson Jesse Stephenson 04/27/09 02:47PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Flagrant - Flagrant - 04/27/09 04:00PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: CtpEDsHED . CtpEDsHED . 04/27/09 05:32PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Jimmy Stucky Jimmy Stucky 04/27/09 06:03PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: paul paul 04/27/09 06:10PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: SchijnHeilig SchijnHeilig 04/27/09 06:17PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Flagrant - Flagrant - 04/27/09 07:38PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: brendanM brendanM 04/28/09 02:16AM
  Re: Octane vs. Compression Ratio/PSI ChartRe: SABAT! andDestroy SABAT! andDestroy 04/28/09 05:58AM
  Re: Octane vs. Compression Ratio/PSI ChartRe: SchijnHeilig SchijnHeilig 04/28/09 06:17AM
