Re: Octane vs. Compression Ratio/PSI Chart
engine compression (psi) and compression ratio are almost completely unrelated. depending on exhaust port duration and positioning, engine compression (psi) values can vary greatly on the same cylinder/head combination. dont count on compression (psi) values to determine if you're compression ratio is high.
with that said however, milling your head will give an increased engine compression AND compression ratio if the cylinder port timings are unchanged. so in this case your CR has increased leading to detonation. i would probably just go up in octane ratings until your detonation is inaudible, then perhaps up another octane rating once you stop hearing the pings just to be safe (at the expense of small loses in power because of unburned fuel).
  Octane vs. Compression Ratio/PSI ChartTopic by: Jimmy Stucky Jimmy Stucky 04/26/09 11:56PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: elliot elliot 04/27/09 12:54AM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Grande Deluxe Grande Deluxe 04/27/09 01:53PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: T. Snider T. Snider 04/27/09 12:59AM
  Re: Octane vs. Compression Ratio/PSI ChartRe: James G James G 04/27/09 01:59PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Flagrant - Flagrant - 04/27/09 02:17PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Raymond Rexroad Raymond Rexroad 04/27/09 02:20PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: paul paul 04/27/09 02:41PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Jesse Stephenson Jesse Stephenson 04/27/09 02:47PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Flagrant - Flagrant - 04/27/09 04:00PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: CtpEDsHED . CtpEDsHED . 04/27/09 05:32PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Jimmy Stucky Jimmy Stucky 04/27/09 06:03PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: paul paul 04/27/09 06:10PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: SchijnHeilig SchijnHeilig 04/27/09 06:17PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: Flagrant - Flagrant - 04/27/09 07:38PM
  Re: Octane vs. Compression Ratio/PSI ChartRe: brendanM brendanM 04/28/09 02:16AM
  Re: Octane vs. Compression Ratio/PSI ChartRe: SABAT! andDestroy SABAT! andDestroy 04/28/09 05:58AM
  Re: Octane vs. Compression Ratio/PSI ChartRe: SchijnHeilig SchijnHeilig 04/28/09 06:17AM
