What are you using in yours
Hmmm .. you have a 6 roller vario..
If so.. remove 3 rollers.. and the little spacer.
On my race bike i was using 3 heavy and 3 medium. On my stock flatreed, 3 stock weights and 3 light.
The spacer went to sleep with the fishes a while ago. I also took out some baffles and cut back the header tube on the stock pipe. Thinking of opening it up to take out the baffle and having it welded back. I'll try the mixed weights next.
Ed any CDI kits left? Did anyone figure out how to time them?
trashfacejoe, what have you done to your bike?
O .. well many parts left.. just email me anytime Dan :) Ed
email sent.
My race bike (piston port): Gilardoni, 24mm mikuni, tjt, modded yz80 pipe.
flatreed: bullet pipe, stock everything else
How fast does your stock bike go?
Dan, Did you take out the little washer/shim/restictor out of the intake... ? Ed
Not yet I wasn't aware there was one but I'll look today.
Ed, Good call on the intake restrictor. I took it out and hogged out the intake with the dremel. Time to order some jets.
:) I smell that cdi.. Dan:) hahha
After I put the stuff on it I'll see about getting that from you. Too much moped stuff in one month and I rack up crazy points with the wife.
They'll be here :)
