hi every one the wiring on my maxi connecting points, coil est is running behind the stator plate. Is this the proper place to wire it??
Just so it's not rubbing on any moving parts, it really doesn't matter where you run the wire just so it's hooked up right...
thanks very much ruevepd, I was just making sure cause the previous wiring looked aful close to the shaft. thanks again
