Re: MAJOR: Which belt to go with for a Hobbit? Pe
stevemke /
are your pulleys good 'n grippey? if your belt is tight but you're slipping a lot you might have grease/oil on your pulley, variator or belt which is bad. (had this on my hobbit, de-greased faces & dressed the belt, problem went away) otherwise if you're not slippin much your start clutch weights might be going to hell. if you can ripcord start it from the flywheel easily there's a decent chance your starter clutch is getting worn out. about $15 from your Honda dealer.
degrease your pulley 'n variator, & dress your belt. tighten everything up nice and tight. if you're belt is still slipping, you've got a problem. if your belt isn't slipping but still hard to start check your clutch.
  MAJOR: Which belt to go with for a Hobbit? Peter?Topic by: Ed Mc. Ed Mc. 04/18/09 12:29AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: roadent$ craig roadent$ craig 04/18/09 01:20AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Ed Mc. Ed Mc. 04/18/09 03:00AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Silverfox Sullivan Silverfox Sullivan 04/18/09 01:27PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Ed Mc. Ed Mc. 04/18/09 02:11PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Daniel Daniel 04/18/09 05:38PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: peter peter 04/18/09 06:01PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Sunset Paul Sunset Paul 04/18/09 08:44PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: D D 04/19/09 01:14AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Ed Mc. Ed Mc. 04/19/09 04:44AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: No Good No Good 04/19/09 04:58AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: peter peter 04/19/09 11:10PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Ed Mc. Ed Mc. 04/20/09 12:47AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: ©h®i$ Stewart ©h®i$ Stewart 04/20/09 01:02AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Ed Mc. Ed Mc. 04/20/09 01:05AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: peter peter 04/20/09 01:15AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Ed Mc. Ed Mc. 04/20/09 01:24AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Ed Mc. Ed Mc. 04/20/09 01:33AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: ©h®i$ Stewart ©h®i$ Stewart 04/20/09 01:54AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Ed Mc. Ed Mc. 04/20/09 02:00AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: JJ JJ 04/20/09 02:30PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Ed Mc. Ed Mc. 04/20/09 04:29PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: peter peter 04/20/09 04:38PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Jeremy Jeremy 04/20/09 04:44PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: JJ JJ 04/20/09 05:02PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: peter peter 04/20/09 05:29PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: stevemke stevemke 04/20/09 06:06PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: JJ JJ 04/20/09 06:50PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: peter peter 04/20/09 07:39PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: JJ JJ 04/20/09 09:08PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: davey davey 04/20/09 09:50PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Ed Mc. Ed Mc. 04/20/09 10:03PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: King Drunky JCams King Drunky JCams 04/20/09 10:09PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: peter peter 04/20/09 10:37PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Ed Mc. Ed Mc. 04/20/09 10:40PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: JJ JJ 04/20/09 11:23PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Ed Mc. Ed Mc. 04/21/09 12:22AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: heather heather 04/21/09 01:30PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: JJ JJ 04/21/09 05:02PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Ryan Ryan 04/21/09 05:18PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Silverfox Sullivan Silverfox Sullivan 04/22/09 12:57PM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: JJ JJ 04/23/09 05:15AM
  Re: MAJOR: Which belt to go with for a Hobbit? PeRe: Raymond Rexroad Raymond Rexroad 04/23/09 07:58AM
