What am I missing Moby Simonini
How the heck does this mount up?
I have nothing to screw into the exhaust.
I have to be missing something.
-Ryan
Re: What am I missing Moby Simonini
header mounts OG threaded style with springs, rear mounts solid and with springs
http://www.treatland.tv/motobecane-simonini-vintage-adjustable-pipe-p/motobecane-simonini-adjus-pipe.htm
ryan,
i had this pipe and couldn't mount it, the angle just doesn't seem right... even if you fabbed up a mount i couldn't see it goin on.
G3 ftw.
Hey Jason,
E-mail those pictures if you could.
I'm having a little trouble.
The av10 head gasket fit perfect the lower gasket not so much.
So, I made my own.
I got the wrong stuff but, treats is sending me the right parts.
-Ryan
roadent$ craig /
i have the circuit simonini moby pipe. the mounting hardware i have is completely different and is probably the same as what your suppose to have.
all you really need is a large nut to screw that flange onto the cylinder. you could probably snag one of a dimoby exhaust and make it work.
Treats is sending me the right equipment.
Thanks for the idea though craigs.
this pipe looks awesome.
Ha,
I ordered this on April 5th.
Today i got the rest of the stuff to put it ion.
It doesn't work!
The threaded piece doesn't fit in the header.
TREATED!
So, this is starting to upset me.
Than, i send treats an e-mail.
I get an e-mail about how treats broke his fingers.
Sorry treats!
It looks like I'm not going to have the moby going for a while.
hey ryan,
let me know how it works out, like i said, i had that same pipe and couldn't make it happen on a moby...
I had the WORST time of getting my Simonini header on to the nut thing too. I ended up grinding out the header 1 entire mm. Lots of work, ugh. You can do it though, make it work!
Hey Mick,
I had to grind it for a good 20 minutes to get it to fit on the header.
Did you have a problem with it notlining up to a mounting hole? (The header)
Its made like a snowmobile pipe.
Did you take the resticor out?
-Ryan
anybody have any performance thoughts on a simonini on a moby? how about pictures? i just bought one and im gonna try to attach it to my parma kit once i get it all set up. thanks
Noah
