What up guys... I own a 86 Suzuki FA50 and was wondering If anyone knew what SIZE AND MAKE jet I would need to rejet a FA50 carb.
Thanks If you can help...
Thanks anyways if you cant...
The FA50 has a Mikuni VM12SH carburetor and the stock Jet is a 77.5. If you go into a motorcycle shop and give them that info they will be able to hook you up.
or delltoro SHA jets work or solder and drill (micro drills/jewelry drills are like 10-35$)
The wiki under other bikes in the performance spreedsheet said 76 jet from a dellorto SHA carb.
With that pipe on.
