A45 hybrid sprint exhaust optinos
so ive got this white thing named the white lightning.
its a 1995 tomos sprint whatever you call it step through POS. A35 CDI bottom end, A55 top end with the stock a55 carb (for now).
It needs an A55 exhaust:
what would you reccomend for it , based apon clearance of center stnad alone? I'm scared of the techno bullet because it looks like a biturbo ripoff, and we know that those all hit the center stand and have mad problems. Ive heard good news on the tecnigas next, but that 1977 colored blitz looks pretty sweet also.
For those of you with a55 tomoses which of you have on your bikes and how do they clear your center stands???
Re: A45 hybrid sprint exhaust optinos
aren't the angles different. I think your gonna have to do the hack and weld dance.
quote from this kit on treats.
"actually for A35 you'll have to mod a pipe and intake too, as the angles on the cylinder exhaust port is different between a35 and a55"
mattology - /
oh my god, did you even read my post?
because i have an A55 top end on it, it obviously needs an A55 exhaust. that way the angles are correct.
You didnt' even answer my question, its for A55 peoplez.
Here i'll ask again in plain engrish:
"those of you with A55 powered tomos mopeds, What exhausts are you running, and how do they clear your pedals / kickstand ??? "
I'm primarily interested in the blitz 1977 thingie. Does it clear pedals and kickstand?
my o8 sprint also has the a-55 eng.
i installed the bi-turbo with no problems to clearance or function plus it's a little more affordable than the technigas
I have pegs no pedals also
Oh my GOd can you calm down.
if you look at the link I included, the quote is talking about putting a A55 kit on a A35 bottom end.
oh by the way that tecnigas next pipe is both rad and fits perfectly on an ALL A55 TOMOS. jerk
mattology - /
god i wish mopeders were as intelligent as the turbo sport compact crowd.
nevermind. i'll figure it out myself, and if need be, tig weld it to perfection, and be sure not to post about it when i do.
YES i am very much aware of the angle differences between A35 and A55.
if( cylinderkit == A55) {
exhaust kit => a55;
elsif(cylinderkit == A35) {
exhaust kit => a35;
else {
exhaust kit => stock;
endif;
Matt the turbo sport compact crowd is pretty stupid too. Most of these people are actually cool though. If you have nothing nice to say, don't say anything at all. I guess you missed that one in elementary school. This isn't ziptied.
Umm yeah Matt, relax.
No need to snap at people, frankly your responses make you look like a dick.
When you react that way, it makes nobody ever wanna help you or give advice.
So again, easy tiger.
a biturbo hitting the center stand? lol ive never seen that but bullet pipes are better then the biturbo. the imperial blitz pipe from 1977 works pretty good and it clears the pedals and kickstand
mattology - /
that's all i needed to know, thanks.
I have run all the pipes discussed. I liked the Blitz Imperial Pipe. It's great quality, however the pipe is designed for a stock 50cc cylinder and increases low end/mid range, however, it was a bear getting to 40mph. It looks like the pipe is too long (too much length of piping). Also, if you noticed the expansion chamber is symmetrical. I usually like a more agressive convergence cone compared to the divergence cone.
The bi-turbo is so-so, it works good for mid range/top end, but the lowend sucks. I got my bike to go 44ish (gps) with the bi turbo and uni pod.
The technigas next R is a very good all-around pipe, but you hit a wall at about 42mph. I know a couple people that have shortened this exhaust and are now getting out to 45mph.
My favorite, that I'm running now is the A35 Bullet Pipe I had to cut/weld the pipe to the get the exhaust flange angle correct for the A55. The header pipe is much larger on the A35 pipe vs the A55 pipe. Another note, if you compare the bullet pipe silencer to the bi-turbo silencer, you will notice that at the end of the silencer the exhaust comes out of a tiny hole and that what looks like the exhaust tip is actually just cosmetic. The A35 bullet gave me more mid range/top end compared to the bi-turbo. I was doing 45mph on my bike with just a unipod and the bullet.
Another awesome choice would be the techno estoril. Once again, it is designed for the A35, so you will need to cut/weld for the A55 exhaust angle. Broader power range than the technigas. Will get you out to about 44-45mph, with sick low end/mid range.
BTW, these exhaust comments/advice was done on stock 50cc A55 engines with unipod
Hope this helps.
mattology - /
Thank you!
I've got a techno estoril for A35 on my A35 alukitted bike right now. maybe it's my jetting, or the fact that it's converted to a side-bleed after being de-restricted, but i haven't been absolutely happy with it.
I will be throwing a 70cc kit on this a45 eventually, and i'll probably just do the A55 airsal kit and call it a day.
I really don't want to be cutting and welding too much on this one. I've done enough of that with the blue disasater. I'd rather just bolt on a pipe and be ready for 45mph with a kit and gearing.
Do you think i can accompish that (While clearing pedals and CenterStand) with the A55 bullet ?
Moped Garmy /
hay matt. what does you know of trikkingout an A3N? heard of one b4 but never seen one. think only a crank is diffrent in them. intrested in seeng what you could make of one. make FL proud.
tron
mattology - /
dude as far as a3 stuff goes talk to jewish his ped is faster than the delorean. but if your'e a tampa dude just come by and say what's up
Moped Garmy /
no. not a3, tho. pretty sure the re was a3n for short time. l ike 1990 or some time near then. mebbe tt-elx models. probly should be asking donp on this but you seem to no lots on these targa mods.
hey bro sell me an A35..
mattology - /
I only have an A55 pedal start case dude, no A35 stuff for sale :(
is it a compleat bottom end ? crank, gears, clutchs,flywheel,stator(cdi if has one )
I am using the stator and ignition coil(i think thats what it is) off an A3-N and my A3 seems to ride out. My roommate has an A3-N sitting around. Just an extra motor.
mattology - /
Yes it's a complete A55 bottom end but i really don't want to sell it so i mean, if you make the right offer on it i might consider it, but come on man, A55's are metra/gila ready only minor case matching..
that was my plan on my tomos polini cup racer...lol
Late model A35's like mine I believe have the same transfer ports as an A55. Lets take off my jug and look!
mattology - /
then take it off and tell me
mattology - /
I went with the Tecnigas.
