Re: Hard or soft seize on a Hobbit polini...cant t
Gym-Me IRE /
OK, rode it home, so yeah, It runs.....
Thanks for all the resposes, but this is what happened....
1.I was running a Spree head= HEATED UP VERY HOT dont ever use one!
2. the metal head gasket had to be honed out to accomidate the piston head, Polini did not supply a head gasket
3. I cut too close to the decompression hole, it blew out and started leaking....
4. Had a Harrd/ soft seize... it was soft cause it didnt freeze up, but it came on suddenly and hard, back wheel locked up
5. When I re ground a new head gaket and installed I thought all was solved.
6. Wait, I had just installed a decomp cable, because I put the stock head back on, yet I am using Magura brake levers, and the travel for the cable is more thatn the stock set up, so it was constantly engaged and decomping the damn thing . My wife pointed down and said look oil/ smoke comming out the decomp piston area.
7.Ripped the cable off and fired right up!
8. Rode it home with no problems...runs like a champ!
  Hard or soft seize on a Hobbit polini...cant tell.Topic by: Gym-Me IRE Gym-Me IRE 04/14/09 07:00PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: Chris Rice Chris Rice 04/14/09 07:14PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: King Drunky JCams King Drunky JCams 04/14/09 07:15PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: R . R . 04/14/09 07:48PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 04/14/09 07:50PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: Motobee Goode Motobee Goode 04/14/09 08:06PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: peter peter 04/14/09 08:32PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: Zeke Zeke 04/14/09 09:06PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: Gym-Me IRE Gym-Me IRE 04/14/09 09:37PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: Ben Ben 04/14/09 09:43PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: leedog leedog 04/14/09 09:44PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: Gym-Me IRE Gym-Me IRE 04/14/09 09:53PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: King Drunky JCams King Drunky JCams 04/14/09 10:05PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: Derek Derek 04/15/09 01:41PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: peter peter 04/15/09 02:53PM
  Re: Hard or soft seize on a Hobbit polini...cant tRe: I R E Rick I R E Rick 04/15/09 09:52PM
